Re: Cupped Propellers?
I do not think you are going to get any more speed just by cupping the prop. On a outboard it can give you a little more speed if after you put the cupped prop on you then raise the outboard. Raiseing the outboard means less drag and more speed. The cupped prop allows you to raise the outboard some without caviatation problems.<br /><br />If your are looking for more speed you really need a bigger motor. You might gain a little by getting a stainless steel prop with a pitch that will put you in the lower end of your WOT RPMS. If your engine WOT range is 4400 to 4800 get a stainless steel prop that the WOT RPMS is close to the 4400 end. This could give you as much as 3 MPH but that is it.<br /><br />Make sure your boat bottom is clean, Make sure the engine is tuned up, Lighten your load, Trim the bow as high as safe. Bottom line is only real speed increase will come from more HP.
