cupped vs uncupped prop
LuckyPenny
I am trying to find out what the difference is between a cupped and uncupped prop. Some said that it adds and inch to the pitch. another said it was designed for the trim systems.
ratt1966
Re: cupped vs uncupped prop
Iknow that on my merc it can't have a cup because that is where the exaust cones out
Wildman95GS-T
The differance between an uncupped and cupped prop is in the design of the trailing edge of the blades. A cupped prop will bite the water better and will allow you to attain higher trim angles and turn tighter before blowing out or cavitating :)
LuckyPenny
OK, I do not have a trim system, so using an uncupped prop would serve me better under these conditions?
