Custom Manifold advice/opinions wanted
KaGee
I have to replace my manifolds/risers.<br />1982 OMC 3.8L V6 (229CID)<br />Here is my existing layout:<br />
<br /><br />The OEM parts are around but extremly high priced. And I want to adapt something like this:<br />
<br /><br />What do you think this guy used ? Is that an elbow/reducer? Is it an 80 degree bend? Is it just hose that goes from the elbow down to the bellhousing?<br /><br />Looking for a little "backyard" ingenuity here. :cool:
rabidfish
Re: Custom Manifold advice/opinions wanted
This is junk. for several reasons. To make a boat engine reliable, keep it simple. If you want to save cash, use the aftermarket manifolds that actually fit. They are available from your dealer/distributor. just ask him to look for them. Or: email me & I'll give you part numbers
KaGee
Ummm Rabid.... the picture is of a 3.8L... That is the OSCO OEM replacement...! GLM has a similar design... both require adaptation from a rear riser to a center riser. Neither.... as far as I know, offer a complete retro kit, which is why I am asking for some assistance.<br /><br />I have the OEM part numbers... just not willing to spend the $500- $700 a side for the project.
tommays
KaGee<br />once your past the riser/elbow as in the photo the exaust has been cooled and surface temp is no longer a saftey issue<br /><br />i cant tell from the photo but it looks they just used a 90 deg street ell and pipe to finish the run <br /><br />if you have a mcmaster carr book they have fittings in every type of material threaded,butt or socket weld<br /><br />tommays
KaGee
Thanks for the input guys.<br /><br />Snapper, I thought that was an 80*. What I have to confirm now is the diameter of the riser output. The bellhousing is 4" I believe or 3 and 7/8 or something.<br /><br />Robby, I plan on buying the GLM's from Moore.<br /><br />Tom, I'll check McMaster Carr... an elbow is an elbow. But I wonder if they have 80* bend?
yoced
The Elbow there is part of Osco kit CRR80x3.5: 80*, 3 inches in, 3-1/2 inches out, mounted on the CRR-2 riser.
