Hello Friends,
First post here, thought I'd share a project I've been working on for my Sevylor HF 280 Fish hunter. Bought a small outboard, and needed a transom!
This was definitely the hardest part to design, I used it to connect the main frame arms to the fittings built into the boat (similar to the manufacturers transom) as seen at the top of this picture:
The frame arms were 3/4 inch electrical conduit, which I bent with a pipe bender. I thought it might be a little stronger and more durable than copper. For the transom itself, I found a solid piece of hardwood at my job left over from renovations that I thought would do nicely.
I wanted to use the manufacturers fittings as much as possible, so I used some short pieces of 1/2 inch conduit pipe which I bent and cut to fit naturally
to be continued...
to be continued...
