I am trying to understand the throttle - shift - cutout switch relationships. I don't see how it could work which doesn't help much. If this is posted somewhere please let me know where. My confusion comes from the following.
1. With the shifter parked and locked in neutral the carb is in idle and the shift mechanism has the cutout roller in the bottom of the valley. It starts fine. Doesn't the cutout roller interrupt power when it is in the bottom of the valley ?
One test says to ohm the switch and move the roller slightly out of the valley to get continuity.
2. When I push the throttle forward the throttle cable moves and the shift cable moves after about 2-3in of throttle travel.
Now that is a big delay. Rev'ng the engine that high before engaging the outdrive. That doesn't look right. Yes I am using the correct cable hookups on the throttle.
3. With so much throttle travel in the middle third where the engine throttle is the only thing active. (It travels about the same 2-3 inches before engaging reverse also) why do I need the cutout at all. When I go from forward to reverse the forward gear is disengaged then the throttle goes to idle.. then the engine is rev'd up and then the shift to reverse occurs.
Everything is brand new/rebuilt - cables,throttle,outdrive,carb,cutout switch.
BTW: The engine dies when I put it in gear. So I guess understanding this could help.
Throttle action
<forward engaged and throttle < engine only throttle > Reverse engaged and throttle>
1/3 total travel 1/3 total travel 1/3 total travel
This is without pressing the throttle only button
Any help would be appreciated
Thanks
OTG
Throttle action
Thanks
OTG
