Re: Cutting hole for aerator
purchase your aerator of choice first many have diff. size inlets from 7/8 to 1 1/2 place it well below the water line in under your splash well area (easy access). On Alu. boat If it does not go though your transom reinforcement use a 4x4 piece of 3/4 plywood inside as a backing plate, use your marine sealer behind it smear it on good this will help absorb noise,keep it transmitting sound thoughout the hull
and READ the directions
good luck
