cutting holes in fiberglass
twinvee17
I am going to be adding some gauges and rod holders on my boat. What is the best way to cut the holes. I was planning on using a electric drill and a hole saw drill bit. Should I start drilling at a high speed or low speed. Thanks
Billnicole
Re: cutting holes in fiberglass
Put :D masking tape over the holes so you dont splinter the glass when you drill threw it
ED21
Master Chief Petty Officer
Hold a backer of wood against the hole too. Try not to drill any body parts.
mattttt25
tape is a good idea. i used a borrowed roto-zip. it made the job quick and painless.
crazy charlie
I have used a hole saw bit for the same thing.Make sure you use a high speed drill.the higher the speed the easier and cleaner it will go.I used masking tape on the gelcoat side.Let the drill do the work,dont push on it.Charlie
snapperbait
You'll need Bi-Metal type hole saws, there the only ones that'll last for more than one time use... With the cheap hole saws, the teeth will be eat up after the first cut you make...
twinvee17
I certainly appreciate all of your replies on cutting the holes. Thanks again. Richard
Jason Adam
Reverse Drill on the hole first. Tape as well. Countersink all your small holes slightly to avoid future cracking.
humbug69
This site is amazing I have always wondered how to stop the gel coat from chipping when drilling, but have just never taken the time to ask, Brilliant... tape.... would have never even guessed. Hopefully I can be of assistance one day :) :)
