boatasiaus
- Mar 12, 2005
- 5
Hi Guys<br /><br />I need to cut my deck fishbox cover in 1/2, and install a continuous (piano) hinge to allow easier opening. Right now, its about 5 ft long. The question is, what to use to cut the fiberglass<br /><br />My thought was to use a downcut spiral bit in the router as they are available in narrow diameters. Online research says to use a fiberglass bit, though to me it looks more like a chamfering bit, and would leave rough edges. A third option is to use a standard double fluted bit. In a completely different approach, I could also use a jigsaw or circular saw, though they would likely leave very rough edges, requiring a bit more glass work. <br /><br />The full project is to cut the cover, then route out the section where the butt portion of the hinge sits, to keep it flush with the deck. I will also need to glass in some type of backing on the inside of the cover to attach the hinge plates. Touch up with gelcoat as necessary<br /><br />Has anyone done something like this before? Any recommendations?<br /><br />Thanks for the help<br />Ted
