Hi all!<br />Im having my merc 140 181 CID 86mod cylinder-head off since I found some water in the oil and cylinders, and I was wondering if there could be something wrong with the head, even if compression is OK (between 125-150) or does that mean that the head is OK?<br />Will a cracked head fill the manifolds exhaust passage with water? <br />Ive done a test with gasoline on the manifold, and couldnt see any leak, it would creep by <br />the riser though.<br />Im doing all this at home on muffs.<br />I used a lot of water washing the engine, is there a valve ventilation where water could come in, and would it then get in to the cylinders?<br />It all looked OK when I took the boat home.<br /><br />Regards<br />Affa
