25 HP...SN# 0B338109........I believe made around 1988..... Mercury 2 stroke...100 psig compression on both cylinders....carburetor perfect.....timing set correctly.....replaced old plugs with new plugs.......spark getting to both cylinders....BUT lower cylinder not igniting....engine only running on one cylinder....starts good...idles fine....and runs at top speed ....just on one cylinder
Friend suggested a problem with the reed valve for the lower cyl.
Any ideas..?
Any ideas..?
