cylinder sleeve chipped at the bottom
Aaron Huyser
New project going here
you can obviously see what happened here the cylinder otherwise feels very smooth all around think she'll keep going with a little cleanup? I put a bore scope in and I don't see any other cracking etc.
F_R
Connecting rod screw came loose? It's lucky it didn't wipe out the whole crankcase. But yeah, I'd say if that is the only damage, you are good to go.
Aaron Huyser
yes your correct and yeah it scuffed the crankcase on both sides like you see in pic but otherwise good I'm gonna clean up the chipped rough edge and make sure there are no little pieces of anything anywhere before assembly.
jimmbo
I would replace that Connecting Rod and its bearings, just as a precaution
