D i w
boats3po
am a first time boat owner, am new to all this, i have a 1988 23ft sea ray sundancer i/o and a whole lot of questions, i have not put the boat in the water yet. any suggestions on anything would be greatly appreciated
Summer Fun
Banned
Re: D i w
Welcome to iboats :). Ask away fellow Sea Ray owner. :)
You need to give a little more info on what you want to know. :confused:
veritas honus
Re: D i w
Welcome to iboats!!!:D
First thing... Take a boater safety course. Stock the boat with PFD's and ALL the safety equipment you'll learn about at the boater safety course. Post a few pictures of your new boat. Let us know what engine it has, what outdrive, condition, any problems we may be able to help with, ect...
Bob_VT
Re: D i w
Welcome to iboats!
You will get any information you need here..... just ask
We have many brother's here ;)
BIGALF
Re: D i w
Living in Philly this time of the year gives you a lot of time to work on your boat before you can take it out again. Take some pictures and send it to us with any questions you have.
macsfriended
Re: D i w
Ahoy and Welcome to the great world of boating.
"Chapman Piloting and Seamanship" is THE BOATERS BIBLE. Don't be scared off by publisher's MSRP of $60. Iboats and other big sellers will often have it on sale in the $25 - $29 + or - range, sometimes less. It is up to its 66th edition. So its longevity tells you it is valued and a keeper.
The answers to most boating questions and lots of good advice, practices and tips ARE there.
I heartily recommend it You will not be disappointed!
Christmas is coming - start dropping your hints for it now.
Good Luck.
boats3po
Re: D i w
i took the boaters safety course passed 97% waiting on certificate, yes am on the pfd's, extinguisher, ring floatation device, waiting for some stuff to be delivered, the boat is shrink wrapped for winter, all i know is that has a mercruiser 5.7L i/o. im not sure which outdrive it has either alpha or bravo. the cover for the boat is on its way. should i wait til it gets warmer to take the wrap off, rough winters in phila. i want to hear the motor run test it so if anything is wrong i can fix it by season begins
shrew
Re: D i w
If the boat is shrinkwrapped already then there is going to be little point to unwrappping it in November. If you can get a set of muffs on the outdrive you could probably fir the thing up, provided the outside spigots where it's stored haven't beenn shut off yet. It will require that you re-winterize the engine when you're done.
It sounds like you bought a boat that you haven't seen float or run. I assume you didn't take it on a seatrial prior to purchasing?
SigSaurP229
Re: D i w
Biggest advice
Don't forget the plug
You will do it anyway.
But KEEP A SPARE PLUG
boats3po
Re: D i w
you would be right. but i got it from a trustworthy individual, (go ahead say it---dumba@%)
boats3po
Re: D i w
Welcome to iboats!
i need info on launching and retreiving the boat, first timer. can you sugest any web sites or videos where i can get some serious info on that. been to youtube but a bunch of comedy stuff
1fishbone
Re: D i w
Welcome to iboats...a great place!
Try YouTube look for the launching/retrieve techniques...don't spend too much time looking at all the fiascos!!
I just bought a boat with a float on trailer ...my first float-on trailer, so I went there to find some videos...I found some and have a better idea.
jcupo6
Re: D i w
what would you suggest i do
Although it does stink to remove the wrap right before winter, I would. Being that you don't really know what condition the deck is in, it wouldn't be a bad idea to check everything out now. If everything is good then you just wasted some time and shrink wrap, but if the deck needs to be replaced I would rather know now then next spring when you want to take her out! Winter is a great time to work on the boat cause you can take it out on the water!
Where do you plan on taking her out, delaware river?
boats3po
Re: D i w
ok, actually i cut a small slit in the shrink wrap and went inside, the deck and everything inside is clean. i mean nice. the seats are not weather beaten, they are leather. the only thing that i see that i can bring up is the teak wood on the swim platform and the door to the galley, the engine has been maintenanced since he got the boat by a mechanic. once i was done i sealed the slit up that i cut in there. i want to be able to go all over with it. salt/fresh water
boats3po
Re: D i w
what was the standard outdrive for a 1988 sea ray sundancer 23ft with a 5.7 l mercruiser engine
Summer Fun
Banned
Re: D i w
If you have a Merc motor more than likely you have a Merc outdrive also.
OMC = Cobra's & Stringers & King Cobra's and a few more I can't remember. :redface:
Home Cookin'
Re: D i w
since you asked about launch retrieve, if you can get to the boat, use the winter down-time to practice trailer-backing and other manuevers, and teach your family members as well. Good to learn without pressure--like an iboats member in a lawn chair at the ramp with a 6 pack and a video camera
