OK.. I did a dumb thing.. forgot to change water intake impeller. 89 OMC 5.7/350.<br /><br />I overheated at launch this year, the engine shut down by the time I noticed. After it cooled, I started it up, and it appeard to run fine (sounded normal). Due to the overheat, I toasted the upper exhaust hoses off the riser, so I replaced them, the thermostat (and the exhaust seals) -oh, and the impeller (which was shot). <br /><br />Anyway, immediately after replacing everything, I started the motor engine, ran it for about 15 minutes, watched her get warm (170-180), cool a bit, and basically stabilize at that temp. Everything sounded normal, ran great - no problems.<br /><br />I went to launch the following day, and the engine would not turn over. It seemed like a weak battery. I would get "half cranks" and could hear the starter hissing (like it was getting power but jammed). I nursed the boat back to my marina on one engine. A couple hours later, I tried to start it again, it was very difficult to start but eventually it did. Now, it appeard to run "rough" like bad gas, or carbon build up. I ran it to op.temp and spayed OMC Engine Tuner in it until it stalled out. I tried to start again immediately, but again, got weak or jammed crank.<br /><br />The following day, after checking the batteries, cleaning terminals and all of the obvious "easy" stuff, I was going to remove the starter (which is not easy) and have it checked. While working around I removed the PCV valve tube and notice some condensation. I checked the valve covers, and they have milkey dropplets in them. I checked the oil in the pan (w/dipstick) and it appears to be fine .. no presence of water, although I am going to drain it tonight, as the water could sit above the bottom of the stick level.<br /><br />My question is.. If I blew a head gasket, or cracked/warped a head, would that in any way cause the engine not to crank over?<br /><br />At this point, I dont know where to start.. rip the heads off, or take the starter out. I'm not sure if the "water" in the oil is actaully water, or if that may be from the OMC Engine Tuner (which is a white liquid in an aerosol).<br /><br />Also, if the head was warped and causing the problem, wouldnt that be presend right after the overheat (the engine ran great on two occasions after the overheat - with no problems).<br /><br />Also worth noting, the last time I attempted to start it, there was a steady "knocking" sound, in 4 swift, percise intervals as the engine cranked. I cant duplicate that again, as now I only get the "half cranks" again.<br /><br />Any suggestions are greatly appreciated!!
