Re: Damage fron charging batteries incorrect and not Saltwater
I am also aware of the "grounding" issue with a motor left in the water and regular battery charging maintenance is performed. The motor anodes should take care of this problem but alas are only as good as the maintenance they receive, i.e. periodic removal of the crusty deposit formation on their surfaces. This Merc is like mine and has two anodes. The main one is the one that is attached below the power trim lift ram and bolts to both sides of the transom bracket. The other is actually the trim tab itself. Normally, the main one will coat out with deposit and must be wire brushed down to the base metal again (zinc is the metal for the anodes and should be bright silver when clean). Also, when the main anode has coated out with corrosion, the trim tab itself will begin to corrode out more. When I perform maintenance on mine, I pay particular attention to the underside of the anode mounts for any corrosion. The anode success is only as good as the contact it can make with what you are protecting.
Some friends on Toledo Bend have had this electrolysis phenomenon also occur and came up with a couple of things that seem to minimize this problem severity. The first is the obvious one, take the boat out of the water on some frequency and perform maintenance on the motor anodes. The second is to install a safety main electric switch called a Perko switch to completely isolate the motor from any battery charging.
Hope this helps.
Jim
