Damaged Dist Gear
FreeBeeTony
Got towed in today!
After some T/S found a bad dist gear (see pics)
Just rebuilt the engine over the winter and installed the CompCams XM270HR Cam.
Just got off the phone w/ CompCams and was told I did not need to replace the dist gear for this Cam. They said maybe the dist gear was previously worn or the bushings in the dist were bad.
I intend on rechecking the dist shaft bushings and see if I can see the cam gear from the dist hole.
Now for the real question.......
What are the chances I can replace the dist gear and re-install?.....if I can see the cam gear.
Ayuh,..... You should be able to see the cam gear, if yer hull will allow a straight down view,......
If the cam gear looks Ok, 'n the bushin's are Ok, I'd just change the distributor gear, 'n see what happens,.....
SkiGuy1980
I lost the distributer gear on my 4.3 merc a few years ago. The cam shaft was clean so we rebuilt the distributer with a new gear and had no problems. Good luck!
alldodge
Looks like the gear was not checked for correct depth and was down to low. Probably need to shim it up some. Install and put some grease on the gear. clamp it down and rotate a couple times, then check wear pattern
Do you have a regular oil pump or other type?
check cam gear, if good, go with a bronze dizzy gear.
Hmmmmm,...... Was the gasket installed,..??
FreeBeeTony
FYI......
I was running ~3500RPM when the failure occurred.
Engine backfired through the carb and engine died......would not start.
When checking the timing it seemed pretty far off.....so I pulled the distributor and found the damaged gear.
I'm guessing the dist, jumped and the timing changed.
Didn't have a chance to get back down to the boat.
Is that dist gear something I could pick up at a auto parts store?
scoflaw
Ensign
If the cam gear looks good , un scathed by this , then the Rockwell hardness number between the 2 gears is different. An alignment issue would show wear on both gears if of equal material
GA_Boater
Was it your motor that the cam gear was too far back on the camshaft and you pinned the gear? Might be another member.
FreeBeeTony
Think I found my problem..........see pics.
Measured the shaft ~0.48.........probably need the 0.491 gear.
Shaft seems a bit worn. Going to see if I can find the gear and bushing and try to use for the rest of the season!
Can I use the shaft to get the bushings out?
scoflaw
Ensign
Go with Comp Cams gear recommendation. The last thing you want is a diz gear that's harder than your cam gear. Unless you have a billet cam you don't want a fast wearing bronze gear. I think the bushing and shaft damage was caused by the 2 gears being incompatible and not visa versa, shafts and bushings can last a very long time
FreeBeeTony
The engine only had 60hrs w/ the new cam........I'm thinking that the bushing caused the gear to fail.
Any suggestions on where to purchase the bushings and gear?
alldodge
Need to make sure I know what your working on, I'm old and don't remember the mix.
Is this a 1984 350 block and distributor?
FreeBeeTony
No, the engine s/n was 0DXXXXX.......350MAG, Roller Cam, TBIV ignition, Weber Carb.
achris
More fish than mountain goat
When posting serial numbers, please post the whole number. Partial numbers are as useful as no number at all.
Chris.......
FreeBeeTony
Looks like the dist gear has 2 sets of holes for the pin to position the gear on the shaft........they're about 0.020 apart in height, Looks like mine was installed using the upper hole making it higher......and the gasket was installed on the dist.
FreeBeeTony
Received bushings yesterday and should get the gear today. plan is to install gear on dist later w/ grease and install w/ gasket, then spin the engine to check wear pattern. will post pics when available. Probably going to run for at least the rest of the season unless it looks really bad. Any other thoughts?
