Re: Damaged Prop?
Yes, and maybe . . . Is the rough idle only in gear? If it idles rough in neutral then not the prop. A damaged prop could definitely cause a reduction in max RPM that an engine could run. Could also cause it to run higher RPM. Any chance of posting a picture?
