richw46
- Apr 7, 2008
- 118
I have a 1995 Merc 4 cylinder 115 HP. Recently my power trim indicator and tachometer quit working. I checked the trim sending unit and gauge and both seemed OK. I ran a wire from the sending unit up to the gauge but it still didn't work. I knew that it tested OK back by the motor so I started checking grounds. I found that the steering cable was the only place the sending unit was getting a ground. I checked the ground straps on the port side of the motor and found them both loose at the dampers. (I guess that's what they're called. Kind of shock absorbers with grounding cables.)
I ran a jumper from one grounding strap to the other and the trim indicator started working. My question is, these dampers were at some point tight, but now they are very loose. I can turn the bolts with my hand, although they are rusted together, they won't fall off. The grounding straps at this point are loose and rusted, not making contact with the metal part of the lower unit. Do these dampers need to be replaced? Can they be tightened? I can't seem to move them to unbolt them.
Thanks
Rich Ward
Thanks
Rich Ward
