Dang reevitts
mphy98
Up in Canada I seem to have lost 2 reevits:D on my starcraft. Yep gone. Didn't notice until I was taking on water. Not that big a deal. I have 2 bilge pumps. I pulled it out of the water later that day and that is when I discovered the missing reevits. So without tearing the floor out can I pop rivit and silicone the daylights out of it before I pop it in?
Bob_VT
Re: Dang reevitts
YUP but I would use 5200 and NOT sillycone ;)
kfa4303
Banned
Re: Dang reevitts
+1 on the 5200. A little dab on each reevitt will be fine.
Auger01
Re: Dang reevitts
Dont just use any pop rivet. I would use blind rivets that are designed for structural appications.
I would wager that a six pack or two and a short trip to your local aerodrome would get those empty rivet holes filled most ricky-tick.
roscoe
Re: Dang reevitts
Been there, done that, several times on the old alumacraft. We beat the ..... reevettes out of that boat.
Temp fix while still in Canada, a small sheet metal screw, or 12.
Haven't popped any on the Starcrafts, yet.
How was the fishing?
I'm not heading up till fall this year.
Georgesalmon
Re: Dang reevitts
Did you shear them off when hitting something? If not you should check for loose rivets all around the bottom. Blind rivets with 5200 will last a while but I would consider replacing them with hard rivets during the "off" season. I had a older "72" 26 foot Starcraft with stringer engine and had a rivet come out. Upon futher inspection I found several other "Loose" ones. Ended up removing the floor and foam and hitting every rivet with rivet hammer and block. I even had to replace several with oversize rivets because the holes were oblonged (is that a word?) out. I ended up with new transom, new floor, new foam, etc. And it all started with a rivet falling out, lol.
mphy98
Re: Dang reevitts
No did not shear off, I just toasted the bottom of the motor. Another story for later. These seem to have come loose on their own. I called my friend Jerry at American Champion Aircraft and I believe he can fix me up!
jigngrub
Re: Dang reevitts
Sounds like the 2 missing rivets are the least of your problems.
s freud
Re: Dang reevitts
I am also looking at replacing a bunch of rivets I don't know anyone with the tool so it looks like I will be buying one but don't know where to start any ideas?
