de carb info
Rob01
Hi<br />I have been looking for sea foam here in Thunder Bay Ontario for the last couple of weeks and cannot find it .... no one has heard of it. <br />I was wondering if anyone knows of or can recomend a product like it that is sold in major retail stores ie. Canadian Tire<br />The local shops all say they have fuel additives etc. but motor has to be torn down to be cleaned.<br />I am looking to clean a 1950 evenrude 2 hp that is running ok but decarboning is long overdue <br /><br />Thanks for all of the great info <br /><br />Thanks <br /><br />Rob
papasmurf
Re: de carb info
Bombardier has a product called Engine Tuner and Mercury has one called Power Tune. They both work well as a decarbonizer.
MarkHPCA
Re: de carb info
Unfortunatly the Sea Foam products are not availavble in Canada. I tried to get some earlier this year and contacted the Sea Foam people to get the address of a local distributer. But, as Papasmurf stated, any 2 cycle decarb product will work fine.
rolmops
Re: de carb info
I know that is not very common practice,but if you take a spraycan with water and spray it into the carb opening while the engine is running,it will do a terrific decarbing job.
