SnappingTurtle
- May 4, 2008
- 1,251
I have a de-rated, horse power reduced 1981, 6HP Evinrude made in Belgium according to a search of Evinrude model numbers.
Visually it has the details of the 7.5HP (no 6HP was sold in the US in 1981) sold Stateside for this year, and not the 4.5. In Germany 6HP (where I bought it) is the upper limit for motors not needing a license, so this is done very often here.
When I picked it up the older man I bought it from said it might be a 7.5 and have a restrictor plate but he wasn't sure. I should check. Can you see this plate without taking the carb off.
I can't see anything other than a gasket between the carb and the head, with it mounted. Does this mean, no I don't have one, or do I need to remove the carb to see this. If not would I need to change to a 7.5 carb.
If it does have a restrictor plate, can I simply remove it, or would I also need to adjust the timing, change the jets, new reeds, other plugs, ...
As always, thanks for any response in advance, sorry if this is a dumb question, or has already been asked 100 times before!
