Boston Habba
- Jul 26, 2003
- 65
Had trouble with my 1987 Merc 175 V6 OB. it began stalling and it got increasingly worse. Last week found water in the #1 cylinder, pulled head a found that gasket was leaking. Also found some nicks in the head as if somthing was flying around in the cylinder. Cylinder walls looked ok, so I hoped that the nicks were old damage taken care of in a past rebuild.<br /><br />Put in the new gasket and did compression check- #1,3,5 120 lbs & 2,4,6,125 lbs. Thought I was ok until I tried to start up. Fired intermittently and wouldn't idle. Also could hear an infrequent but definite knock, like metal hitting metal. Obviously something broken.<br /><br />I do't have the $ to replace motor so I am going to pull the power head, open it up and check out the problem. At that point I can fix it or trash it. Experienced opinions would be greatly appreciated.
