Dead battery
Ralph V
How do you open the engine hatch with dead batteries on a 330 Sgnture?
Thanks
go under the helm and hot-wire 12 volts to the red wire going to your key switch
jimmbo
I hope that the fuse(s) on those Circuits haven't burnt...
alldodge
Just so happens met a guy who had same issue with a Chap just different model. He noticed it before this happened, and cut a hole under one of the seats just enough room to be able to reach in and pull the pin.
If you have a anchor windless, connect battery charger
And have you tried connecting house and start bat together at switch? Watch the switch be under the hatch like the guy I met
