roughshot
- Jul 14, 2010
- 164
Well, over the past two weeks I've run 4 liters of seafoam thru my motor in hopes that it would clean out what ever was keeping my motor from running at idle.
Here is the issue, the motor will idle but will starve out after 20 or 30 seconds, won't shutter, just cuts out. If I pump the choke in the key, it will keep running.
After starting and at idle, the motor seems to have a spot early in the trottle up were it will bog or cut the motor out completely, again, if I pump the choke, it will keep running.
mid range and wot run beautifully no shutter or hiccups and definatly runs better now after the decarb.
Thoughts? Solutions?
Thank you.
Thank you.
