decarb lost #2 cyl
hardtime
Rude 150xp/1990 would not run to 5500rpm low on #2, decarb now #2 has 30psi all other 90psi<br />before #2 had 60psi. ? can i get the leaf stop & leaf valves with out hold rebuild kit. need good<br />parts brake down of motor. :(
Dhadley
Re: decarb lost #2 cyl
What you really need is a good service manual.<br /><br />It'll more than pay for itself on this project.<br /><br />Good luck!
rickdb1boat
What manual do you have? My Factory Manual shows almost every breakdown of every component on my motor. If you have a generic Manual, consider a Factory Manual. The Decarb probably washed away the carbon build-up that was helping seal the rings and that's where you lost more compression. Just a theory.. Check it again.<br /><br />Factory Manual:<br /><br /> web page
LubeDude
What product and procedure did you follow for the decarb, It sounds to me you may have not done it right.
