Re: decarb method/products/additives
Flood the warm engine out using the product of your choice, and let it sit overnight.<br />Have a set of plugs handy, as it does something to plugs .I don't know why, but they tend to foul often after such a treatment.<br />I use ValveTect spray, but they all werk fine.<br />If your manual recommends an alcohol-free fuel,
do not use the additive types, as they can devour rubber (valve seats, seals, fuel pump diaphrams ect).<br />But from what I understand (double check by all means as I'm bnot an OMC guy), OMC even recommends Seafoam additive! Go figure
<br />There was a guy on a Florida-based boating/fishing site who used a shock-treatment meathod, by mixing additive to a small 1QT can of fuel, and running the engine until gone, letting it sit overnight, and then running fresh mix until the smoke clears...And it will smoke so heavily, don't be suprised if the nieghbors call the fire department.<br />By the way, you may allready be aware of this, but mention it in case you are not -- don't run it without thermostats for any length of time.<br />The heads and/or manifolds can warp, and the engine could actuially run so cool as to break a ring.<br />The way this point was driven home to me (on this site iuncidently, was "If the engine didn't require thermostats, the manufacturer would've left them out, and pocketed the 5 buks per motor that was saved".
