Decarb?
neilschaal
I have been told that I should decarb my 75HP Force outboard (1997). What exactly is a decarb and what supplies should I look for? (Where would I get the supplies would be helpful.) Thanks
roscoe
Re: Decarb?
Your intent is REMOVE the existing carbon buildup from the cylinders, heads, and rings, a spray decarb solvent product is needed. Buy at least 2 cans of decarb. Some people use one can per cylinder. NAPA auto parts or similar store or a outboard dealer should have it for you.<br /><br />Run engine at fast idle, with engine running, slowly spray liberal amount into each carb,<br />spray some more, spray a larger amount into carbs until engine chokes out and stops,<br />remove spark plugs and spray decarb liberally into each cylinder, install the spark plugs, let it soak for 1 to 10 hours. <br />Start the engine and run at medium throttle, or if at the lake, run it at full throttle. It won't hurt to spray some more through the carbs. Run it for atleast 10 minutes to flush the crud out of your engine. Now remove and clean, or replace the spark plugs.<br /><br />It works well to do the spraying one day, let it soak over night, then run it at wot the next day when you go to the lake.
Deuce22
Re: Decarb?
Neil,<br />Just a word of caution when you let it sit for a while then restart it , it will smoke like crazy so don't be alarmed!<br />Deuce
