Re: Decarb
Mo-jo....easy to decarb. Look at the primer solenoid and see if the red handle is equipped with a maint. valve. If it is, it will look like a tire valve with cap. Get a can of decarb that has the screw on attachment for the maint. valve. (a Johnny/Rude dealer can help you with the maint. valve and decarb) Follow the instructions on the can. Basically, you run the engine until up to temp. and inject the decarb into the carbs until the can is used up. Let the engine set per instructions on the can and then restart.<br /><br />Your engine is a Looper.
