Decisions decisions Sea Ray vs. Bayliner
bunk02
Okay, I am well aware that many boat snobs will laugh at this choice but I'm seeking some advice. I can possibly trade my 20' Flotebote with 40HP Mercury even up for EITHER a 85 Bayliner Capri openbow with a 2.1 Volvo inboard or a 92 Sea Ray 160 openbow with a 60HP Mariner outboard. I want a RELIABLE boat with some pick up, like enough to pull a tuber. Any suggestions??
puckhead
Re: Decisions decisions Sea Ray vs. Bayliner
Can't say much about the Bayliner, but, the 'Ray came from the factory with a Merc 100. The max on that I believe was 125. Don't know if that's going to be what your looking for........
-T
ezmobee
An old I/O is going to suck more money out of your pocket than an outboard. While I'd prefer a 90HP on that SeaRay, the 60 should do what want it to do. It should even pull a skier if there's a light load in the boat.
avenger79
what size is the capri? will 16 foot be big enough with the Sea Ray? you're going from a 20 footer may be a bit cramped. if it were me and I'm not that experienced with boats, all things being equal I would take the Bayliner with the i/o. I prefer 4 stroke to 2 stroke motors.
Philster
1985 seems realllllly old for an I/O. You can tube off the smaller boat, but of course it will be limited in how fast/strong she'll pull.
bunk02
Never had an inboard before, but I always assumed they would be a hell of a lot easier to work on than an outboard. The Merc 402 I have on the tooner is a nightmare to work on, I can't imagine the Mariner is much different. We usually only spend 3 hours or so on the lake at a time, so I assumed that gasoline wouldn't be that big of a factor. More so is the fact that the lake we are on is unlimted horsepower and I am sick of getting swamped liek I do puttin around with a 40 on a tooner.
ezmobee
The engine itself it easy to work on. It's all that other stuff between the engine and propeller that's not.
bunk02
The only thing I know that is wrong with the Bayliner is that the power trim doesn't work and the mariuna he took it to told him it needed a whole new unit. The points have been replaced this spring. As far as I know there are no problems with the lower unit. It's a volvo 2.1 4cyl engine which I am not too familiar with but am currently looking up info. on. Going to look at it tomorrow.....in person, I've got pics already.
WIMUSKY
Volvo drives are excellent, dependable and usually trouble free. I have a '79 260A with a 280 outdrive. Bigger than what you're looking at, but I never touched the drive except for changing the gear oil. They're very smooth when you put it in gear. Unlike other makes that bang into gear. But still, as a whole, an outboard is less likely to have issues. Easier to winterize too..... A Mariner is a good outboard.....
bunk02
Well the guy with the Sea Ray blew me off, so I obviously went with the Bayliner. Pretty happy so far, the seats are the only cosmetic issue with the normal vinyl wear. Hell it even came with a marine CD player built in and a kick *** depth finder. Not to mention bimini top, and cover for the open bow and actual boat. Just wish it was spring now !!!
Lyle29464
If you live in cold county please learn how to winterize it
bunk02
Already there on teh winterization, in the past I have always had the storage lot where I kept the pontoon at winterize it. They said it'd be $140 for an I/O not sure if that is bad or not. Anyone have any input on having it shrink wrapped? I always wanted to have the tooner done because it didn't have a cover at all. However, the Bayliner has a bow cover as well as deck so nothing would be exposed to the elements aside from the cover itself. I live in Ohio so winter could produce 6 inches of snow or 6 feet....ya never know.
