Deck an stringer rebuild!!
BETZ954
hi, i recently bought an 82' bayliner capri, i think its a 1950 model??
i knew it needed some int. work so, i started tearing into it as soon as i got it. so far i found that the work that it needs, kept adding up. everything is wet under deck.
it is my first time working on a boat but think i can do it all myself. i have most of the deck cut out(used cutting wheel on grinder) but my progress slowed when i got to the parts under the dash. will i need to put some kinda temp. supports to help hold there weight when i cut below them??
also near the back of the boat, where the seat framings are next to the motor. does anyone have any tips on to how to remove that section of the deck and apart from the transom. (transom seems pretty solid).
BETZ954
Re: Deck an stringer rebuild!!
OK BEEN A COUPLE MONTHS AN A FEW FISHIN TRIPS BUT IM FINALY GONNA PUT UP A FEW PIC TO SHOW SOME PROGRESS ON THE REBUILD. HERES WHAT I GOT SO FAR. I NEED TO UPDATE AGAIN TOO SINCE THERE HAS BEEN ALOT MORE WORK DONE SINCE LAST PHOTO..
http://picasaweb.google.com/BETZ954/BAYLINERREBUILD#
allpoints360
Strong work, Betz. She is going to be as good as new.
