Deck Lights/Courtesy Lights
ShawnQ
I've got a 19' Blue Wave Center Console boat.<br /><br />I often fish at night, and I find myself using the rear white pole light as my only light source on my boat. <br /><br />I was considering installing some type of flush mount lights onto my center console while I have my wiring torn down for a re-wire.<br /><br />I have seen a few circular LED's made for compartments and livewells. Would these little LED lights emit enough light to allow someone to bait a hook?<br /><br />I know they would draw less power and last longer...which is an added bonus.<br /><br />Also, do they come pre-wired with a resistor to allow them to accept 12V current or do you have to wire one in? I've wired LED's into circuits before and always had to add a resistor. It appears that these come ready to tap into a 12V source.<br /><br />Thanks in advance.<br />Shawn
jlinder
Re: Deck Lights/Courtesy Lights
They come all set for 12 volts and draw very little current. I bought orange trailer clearance lights and mounted them in hidden spots on the sides of my boat so they shine on the deck.<br /><br />End result is a really nice look, doesn't hurt your night vision as much as white lights, low enough of a power draw that you can keep them on all night, and they are fairly cheap.
swist
There is quite a brightness difference between red and white LEDs (getting white LEDs to work without being too blue is technologically difficult). You may find that red ones actually light the area better, not to mention the night-vision benefits.
