Deck restoration - Deck paint over poly resin
CILO
Hi all, I'm in the process of completing my deck restore and decided to go with painting my deck with Rustoleum marine paint and later making a snap-in carpet to lay over. My question is, in applying my final coat of resin on the deck should i add wax to the resin or will i get better adhesion leaving the resin unwaxed and painting over that? Also, is there any difference between Rustoleum marine and regular rustoleum industrial oil based?
tpenfield
Re: Deck restoration - Deck paint over poly resin
Gelcoat might be better than deck paint . . .
The wax allows the surface of the poly resin to cure, so you need that. Then you will want to remove the wax and sand the surface in preparation for the paint.
Sooo, a better approach might be to do the poly resin with no wax and then gelcoat with wax and you are done.
ondarvr
^^^^^ Just like he said.
CILO
Understood, guess i gotta put in another order to us composites. Next question, how much gelcoat would i need to cover a 6x13 area? Also, how many coats would be needed?
Yacht Dr.
Im not sure..but I think having carpet over the Rusto is not a good Idea.
Gelcoat would be a better product for that application as already stated.
YD.
