Deep Cycle battery question.
BILLDON
I have a 5.0Gi PEFS (fuel injection). I recently noticed that the manual cautions against using a deep cycle battery as the starting battery on fuel injected engines. Does anybody know the reason for this? I have a deep cycle and starting battery in my boat and have been putting the battery selector switch to "Both" and everything has worked fine. Just wondering if I am doing something wrong.
Re: Deep Cycle battery question.
deep cycle has a lower CCA rating that can lead to low voltage while starting and the fuel management computer doesn't like that. Normally this would only be a problem if the engine has to be cranked for a long period of time before it starts.
sweet addiction
It depends on the size of the deep cycle battery and the requirements of the motor it's starting. The deep cycle batteries I use have 845 marine cranking amps and they work just fine for my boat.
BILLDON
Thanks guys. So far it always starts right up, but I will certainly keep that in mind. I was just wondering what the basis of the caution was, and I now know. It makes sense to me.
dingbat
I run two deep cycle batteries. No problems starting the boat in warm weather. When it gets cold I'll use both for good luck
