turtle1173
- Nov 29, 2001
- 437
Hi all,<br /><br /> I have a compression problem in my 1972 85HP Chrysler. The low cylinder has been registering around 70 while the others are around 127. After some testing I figured it was the head gasket.<br /><br /> I just pulled the head and sure enough, the metal ring around that cylinder is broken on the bottom.<br /><br /> All 3 cylinders have light scratches on them (some worse than others). Is there any reason to concern myself with this or should I just replace the head gasket and go on?? How do you define a "scored cylinder?" Any scratches or just gouging?<br /><br />Thanks,<br /><br />Shane
