ledzeppelin135
- Jul 27, 2011
- 129
Hello, I have a 1983 50HP 4 cyl and after years of tiliting the motor, some gas has managed to seep out the carbs and spill onto the "deck" area that surrounds the powerblock and has become increasingly greasy. I noticed that there is some sort of a spill shelf directly under the carbs that has a little drain that looks to drain somewhere around the base of the block, and I am wondering how I would go about degreasing this area of the motor. The powerblock and all the sensitive areas of the motor are totally clean, just the base needs cleaning. Also, I noticed that there are two wires I can see coming from under the flywheel that lead down and towards the front of the motor and they are mildly rotting, the case of the wire has deteriorated and the wire itself is nearly green. I have some shrink wrap and can i wrap these wires in this and shrink the wrap to strengthen these wires or no? Thank you!
