Hello.
I just bought a new electronic ignition. Delco EST.
I wired it up and started the engine. Everything worked fine. I put in the jumpercable and adjusted the timeing till 6 deg. btdc as my manual says.
THen I took the jumper away and put in the black wire.
When I then use my strobe I can see that the ignition foes up to 20 deg. around 1500 rpm.
Anyone knows how too adjust the advance curve or is there a box or something I can get too make this work??
Thank U very much for all help and tips.
