Re: delete
Well.....WIrED....engine hp power makes a difference and how it's rigged to the boat. Does the engine have Trin and Tilt? Need a little more details on the rig. The situation where the prop sounds like it's slipping could be cavitation....this is where the prop is to far out of the water and drags air into the prop causing it to lose "grip" with the water. Could be a lot of things causing this. Engine to high on trasnom, engine tilted out to far, wrong pitch...Lot of variables to play with. Even a simple thing like a pitot tube for the speedometer can cause ventilation. So...if ya' could....add some details of your rig.<br /><br />Thanks.
