Have an older model depth finder which has a dial type face with a "spinner" which produces a red dot to indicate depth on the dial. When on, the spinner works but reads 0-3 feet regardless of the actual depth. A wire runs from the unit to the transducer which is mounted beneath the V berth. I guess it's the transducer.....it looks like a ~1" pvc pipe about 6" long sealed to the hull, with the wire going down thru the top. Question....Does the transducer ping thru the hull? Because there is no thru hull type fitting on the outside of the hull. Just trying to make this thing work. If anybody has any ideas, I'd be grateful.....Gary
