Mercuiser, bravo III, MPI. Forgot the model number but is a 2001 boat.
Ran with drive trailered up then had a rhythmic thunk come from drive area. I removed the drive and found I couldn't turn u-joints without using a screwdriver. Rebuilt drive then was able to turn u-joints like they are supposed to be turned. Installed drive and started up engine and found the same thunk, went and replaced the gimbal bearing and tried again but found the same thunk.
Now I am goind crazy, everything in the transom area feels perfectly fine. If it weren't for this thunk i wouldn't think anything at all was wrong. It is a strong enough thunk to shake the engine and it seems more random than timed with the engine. What should i do, i take off the drive and inspect everything but everything turns free and feels fine....
