brodie123
- May 4, 2008
- 279
Hi All;
Before I pull out the cam and crank, I usually find timing marks for the chain or gear.
This is a Mercruiser 3.7 inline 4 and has a different timing gear from our other boat.
I see that the pins face each other on every other rotation, but there must be a better mark for re-assembly. I was thinking of making a score mark on the chain and cam and crank gears prior to removal. Any suggestions here for proper removal/assembly to ensure proper timing?
Also, the cam has heavy wear marks where the seals sit for the water pump causing a leak. Otherwise the cam seems fine. Would a good machine shop be able to build it back up and machine it to proper specs? Cam replacements seem to run around $350+ and my budget is going towards a rebuild kit, machining etc. I prefer not to use sleeve if possible.
thx!!!
thx!!!
