Can you tell me how to determine the correct height the motor should be on the transom? I have a 50hp Mercury mounted to a 17.5' Generation 3, modified V, Aluminium. As a point of reference, the plate above the prop is approximately 2" above the bottom of the transom. I am having problems trimming the boat out and I believe the motor is sitting to high on the boat. Right now, the motor is on the 3rd set of mounting holes. Also, how do I do this without getting killed? I thought about using my floor jack and a 2 x 4 combo against the bottom of the motor mount...then I thought that I better ask before leaping. Also if you have any spare rain; send it to Nashville. We are so dry down here that I caught a catfish the other day with chiggers!
