i have a 1998 200 efi mariner offshore.i see the wire that comes out of detonation module thats suppose to go to detonation sensor and it is cut and now goes to a ground. does that mean now that detonation controller assembly is not advancing my timing now. i read if detonation controller detects that if detonation is not present it advances timing 6?- 8?. i didnt know since wire is now cut if it stills advances timing or not or if since cut and grounded that it will never detect detonation and will advance timing like normal. cause on mercury manual it says set WOT timing @ cranking speed at 16? BTDC. it set this low because of detonation controller assembly will advance it. but since wire is grounded and if not working ill set it to where its suppose to be @ WOT while running which is 22? BTDC. when i got motor sensor was already gone and wire was grounded. another thing i wanted to ask was i heard since now running with ethanol gas that its better to set timing minus 2?.in my case instead of 22? it would be 20? @ WOT. or would it be best to set it where it suppose to be no matter what fuel is used. please help a brother out cause i think i got my timing wrong. dont want to cause any damage. if i do got my timing set to high what all would it do? thanks in advance
