DEXTRON for FOGGING oil
crazy charlie
An employee at a local boatyard recently told me that they use tranny fluid to fog their customers motors.He said they can buy it in bulk and it works like MMO.Any opinions????
Fordiesel69
Re: DEXTRON for FOGGING oil
Really I beleive any oil will do the trick. However finding an oil that will travel to the cylinders without the sparkplugs being removed may be difficult unless the product was designed to.
And storing a boat over the winter for only one season at a time should never rust the cylinders anyways even without fogging.
crazy charlie
[QUOTE
And storing a boat over the winter for only one season at a time should never rust the cylinders anyways even without fogging.[/QUOTE]
I totally disagree !!! Charlie
a70eliminator
I didn't fog my I/O but it only sits for 6 months, same with my mowers, motorcycles ect. and they all start right up in the spring, I do have an old Lemans 427 racing engine that was pickled up about 10 years ago with fogging oil along with backing off the rockers so all the valves are closed, in my OMC owners manual fogging is part of the recommended winterization.
Oh and I have heard the oldtimers talk about trans fluid poured into the carb to clean valves.
grahamh
I've used dextron in Volvo car engines to free "seized" engines when the rings have rusted to the cylinder walls.
That said, I wouldn't do it, tranny fluid is pretty gnarly, corrosive stuff. Plus it burns like hell, so working with it around a hot engine is dangerous.
a70eliminator
I didn't think trans fluid was that harsh and corrosive, I've spilled a bunch of it over the years and even mopped it up with my hair, it seems like it evaporates.
bigskiohio
Master Chief Petty Officer
it it not corosive it has extra detergent in it if i remember right, brake fliuid on the other hand is .
TilliamWe
Banned
Trans fluid is thin and has lots of detergents. No problem at all with using it as fogging oil. Except it usually isn't cheaper than oil, but if the shop says they get deal on it, then so be it.
I have used it as a fogging oil before, and I have used motor oil. it doesn't really matter, as long as it's oil.
jtybt
Just use fogging oil. If you can't get it, use 2 cycle oil. At least it's meant to burn. Don't use regular motor oil, it's not made to burn and it will leave carbon deposits.
WIMUSKY
That's interesting. I've always used SAE 30 motor oil. Sure gets the smoke rollin'. Maybe I need to rethink that option. Too late for this year tho.
Lou C
Although any oil will work...I feel safer spraying something into the carb with a spray wand...then pouring...oil onto a warm engine...plus I think the aeresol products are formulated to stay on cyl walls and not run off during the winter....
grahamh
You're right, I got it mixed up. It is, however, quite flammable. Ask me how I know!
lol
crazy charlie
I never said I wanted to use it.I only use fogging oil in one hand and MMO in the other hand combo.Charlie
