DF150 thermostat: 120 vs 160 deg.
jack daniels marine
2014 Suzuki DF150
Hey folks,
There are 2 original Suzuki thermostats available for the DF150. 122 deg F and 160 deg F.
I use my boat in water temperatures down to 40 deg F in the winter and up to a max. water temp of 72 deg F in the summer.
I do only about 60hrs per season , mostly in water temperatures of 46-72 deg.
Otherwise I take a short run or two mid winter if the area is ice free just to exersize the motor.
No engine starts close to or below 32 deg F.
Which thermostat is best for my use?
The motor temp allways runs at 136 deg F with the 122deg thermostat. That's too cold for a car anyway, Is it too low for an outboard?
should I raise the operating temperature by switching to the 160 deg thermostat?
There are also 2 viscosities of motor oil to choose from prescribed by Suzuki: SAE 10w-30 and 10w-40.
I use 10w-30. These 2 viscosities are quite differant around 32-50 degrees, 10w-40 may be unnecessarily viscous for my temperature range
Worst case:
If I use the 160 thermostat, the engine temp will probably run at 175 or so. Would that cause problems , cracks due to the temperature difference mid-winter?.
175 deg cylinder head with 37 degree cooling water?
dingbat
What does the manual say? It should give you a temp reading at idle and at high speed.
Cold water will have minimal if any affect on operationing temperature once the motor is up to temp.
Fished Saturday. 140 stats. Water temp 36 degrees. 135-138 at idle, 158-162 at speed. Right on spec.
jack daniels marine
The workshop manual says:
thermostat opening temp; 58-62 deg C , that's 136-144 deg F.
However the original suzuki thermostats for these motors are either 122 or 160 deg F ( 50/71 )
My DF150 runs at 58 deg C / 136 deg F at idle at at full load, both mid summer and mid winter. ... Just seems a shade low, though I am thinking compared to a car.
158-162 at speed sounds better.
lakensea
You cannot compare outboards to autos. Salt water cooled engines must run colder so the salt does not crystalize in the water passages. 50 degree thermostat is correct for your engine.
