2001 DF60 Keeps draining the battery while it's running. I have tried 2 new batteries now and the same thing keeps happening. Boat does not have a volt meter, but I have put a volt meter to a fully charged battery before & after starting the engine and the meter reads the same voltage while running (almost 12 volts). So it is not getting a charge because if it were it should read a little over 12 volts right? When running it will drain the battery within a 20 minute ride and not crank back.
I unplugged the 3 lead connector (yellow wires) coming off of the alternator and all three read a/c voltage that increases & decreases with engine rpm increase & decrease. So I know the alternator is putting out. What would you suspect the problem is. These parts are too expensive to be chasing with money to trouble shoot like I did with the Power Trim Tilt relays.
Thank you
Thank you
