Diagram Neded for 1996 90HP Tilt/Trim
dinikin
Got little electrical issue, power trim/tilt goes only UP when battery hooked UP, when I press down button it will trave down but as soon as I let go it will go UP.
I think I got some corrosion in one of the swithces or relay.
Can someon post a pic of the Electric Schematic Diagram.
Thanks
AMD Rules
Re: Diagram Neded for 1996 90HP Tilt/Trim
Have a peek at these attachments...
Don S
Before you start doing a lot of testing and wire tracing, disconnect the trim wiring on the engine cowling. (had 2 of those switces go bad like that on custormes boats last year). If it still does it reconnect those wires and disconnect the Blu/wht and Grn/wht wires at the main plug on the harness.
In those 2 steps, you have eliminated the helm switch and wiring and cowl switch as being problems.
