Diagram of how to rebuild fuel pump, need help
lpguy76
Hello again,
I have 83 johnson J175TLCTE motor and took the fuel pump off to rebuild and did not have the right gaskets. Well I had it all laid out as to how I took it apart and when the gaskets did not match I completely forgot how to put it back together. I know it was a bone head move but it is to late now, so if anyone has a diagram of the fuel pump and how it goes back together I would appreciate it. If anyone needs the part number or if that helps it is 398514.
Thanks again,
John
HighTrim
Re: Diagram of how to rebuild fuel pump, need help
If you cant get a manual, highly reccomend you do though, and no one has a pic on here to post, your local library will be able to help you out. gl
lpguy76
Hey thanks for the help so far, the link that Xcusme gave was good but my pump is different than the one they show. The other link just shows the screen instead of the actual pump itself.
