Diameter and Pitch
bassinbrunner
The stock prop on my 115 hp v4 1996 johnson is 13 and 7/8 x 19(diameter and pitch). Would replacing it with a 14 0r 14 1/4 diameter and keeping the 19 inch pitch make much of a difference? The performance was well with my old prop, but am looking at a hustler on ss prop and most are not offered at the stock size I had on it originally (the 13 7/8 x 19).
walleyehed
Re: Diameter and Pitch
13-7/8 to 14 you won't notice any difference in the same prop, but you are dealing with 2 different designs. Although stated as the same pitch, you may see some slight variation in RPM, and could be either way....usually not a big issue.
