Diameter vs pitch
Re: Diameter vs pitch
Ayuh,... Diameter is determined by the motor/ drive it's going onto, 'n the Engineer who designs the prop...
When Prop Shopping, you're looking for the Pitch that works best with yer boat, 'n motor...
Diameter usually just takes care of itself...
Silvertip
Unlike cars and trucks where you can swap the 16 inchers that came on the vehicle with 20 inchers and rubber band tires, you can't do that with a boat. You first locate a series of props that fit your motor. This is not in a range (for example) from 10 inch diameter to 20 inches. Anything other than the prop series designed for your engine will either be way to small or it will hit the AV plate. Once you have a series of props for your xxxx Model xxxx outboard, you chose the pitch you need based on engine rpm. Studying the series of props you will see that as pitch goes up, diameter comes down slightly. As pitch comes down, diameter goes up slightly. The 75-90 HP series of Merc engines takes a 13-1/4 x 19P prop which is pretty standard. You can't put a 15 inch prop on that motor. Nor would you put a 12 inch on it. Going to a 21P would probably put the diameter at 13 inches. Going to a 17 might leave diameter at 13-1/4 or possibly 13.5. So diameter changes but only slightly and it is a function of prop design. You don't shop for diameter. You shop for application, then pitch based on WOT rpm.
tayznild
I own a 2001 four winns 205 with a 4.3 and sx 1.89.any recomendation? I have no prop now to test.
craze1cars
You own a boat without any prop at all? Very odd....
My best guess for you is to go to Four Winns. Here's their site for past specs:
http://www.fourwinns.com/past_product/specs
Find your model, read the performance specs on the boats for your motor combination and see what prop they spec'd from the factory when it was new. Probably the best starting point you're gonna get.
I looked there for you, but according to their site a 2001 Four Winns 205 does not exist...or I overlooked it anyway.
Silvertip
You might try the Merc website. They have a prop calcualtor for outboards but not sure if they have one for I/Os. That would get you in the ball park if you know the approximate all up weight of your boat. Again -- you shop first by application. You must then pick the pitch. See the MARINE STORE button in the blue band at the top fo the page. Go there and look at the PROPELLER section. You do need to know which model year, engine and outdrive you have. Once you key in that data you will be presented with a list of availble props. From there you are on your own unless you know someone who has the same identical boat AND it is correctly propped.
