Did I burn my Johnson 5.5 HP ?
Nakko
I am a newbie to outboards and I love boating and fishing. I bought an aluminum boat with a Johnson 5.5 HP outboard, I got it to start but it smoked a lot and I couldn't keep the idle, I tried adjusting the top and bottom knobs (Lean and Rich) and all of the sudden fire came out of the engine and stopped. Did I burn the motor? what can I do? I would really appreciate your help and guiding me on this issue.:confused:
jasper60103
Re: Did I burn my Johnson 5.5 HP ?
Welcome aboard and sorry about your misfortune.
And fortunately you weren't injured.
I'm sure some of the experts will chime in soon.
Daviet
You need to start with basic checks, compression, spark, fuel delivery. Has the engine be sitting for a period of time? If so you will probably need to overhaul carb. The smoke is from the oil/fuel mix. You did not say what model you have, but you should mix fresh gas with proper oil ratio.
Nakko
thanks a lot, by the way, is a Johnson 5.5 HP Sea Horse Model CD-10
I was reading the link, I will follow it and see what happens. Thank you very much for your quick response.:)
