sambluckie
- Jun 27, 2012
- 24
If I over trimmed the lower unit, could the drive shaft assy cause damage to the bellows? The reason I ask is that when running boat at WOT, I can only get about 3800 rpms using the trim switch. I used the trailer switch to get up to 4100 rpms. Now I have a constant leak coming from what I believe to be the drive unit in the transom. Thank goodness I have an auto bilge pump.
If overtrimming caused my leak, is that why trim sending units are set to avoid this issue?
1985 Wellcraft
3.7 litre 4 cyl
Mercury Vengance 19" P prop
1985 Wellcraft
3.7 litre 4 cyl
